2005 Toyota Corolla
THAROSOO
  • 2005 TOYOTA COROLLA
Shakes or Wobbles problem
2005 Toyota Corolla Front Wheel Drive Manual 34000 miles
bought a corrlla t sport drove 30 miles then engine manage light vsc and trc on then sudden tempreature rise then to normal again. Stalling and revs going up and down and rattle from underneath may be cat converter lookiing like taking car back formy money but wish it could be a cat change and a few sensors what you think
Sunday, September 12th, 2010 AT 4:29 AM
WRENCHTECH
  • 20,761 POSTS
The "check engine" light is an indicator for a system that monitors many electronic functions in the system, also called the "malfunction indicator lamp" (MIL). It can come on for any of hundreds of different causes from any of the systems that the computer monitors. Some are very important and can lead to further component or engine damage and some are emissions related not as serious but still a problem and need to be repaired.
Your first step is to have the computer scanned to retrieve the trouble codes that were set when the check engine light came on. Those codes will give you specific information about what the computer saw and will get you pointed in the right direction to find your problem. With a 1996 or newer and some 95 cars and you have an AutoZone or Advanced auto parts in your area, they will read them for free. Once you have these code numbers, we can be a lot more specific about what your problem may be.
Sunday, September 12th, 2010 AT 7:02 AM
