HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Drivetrain
Transfer Case
SPONSORED LINKS
2005 Toyota Corolla
STANI
MEMBER
2005 TOYOTA COROLLA
Engine Performance problem
2005 Toyota Corolla 4 cyl Two Wheel Drive Manual
Please, send me an answer why my Toyota has not enough acceleration.
Thursday, December 10th, 2009 AT 11:56 AM
MMPRINCE4000
MECHANIC
There are literally dozens of reasons, fuel pressure, ignition/ignition timing, VVTi problem, crank/cam sensor etc.
Best advice is to go to Toyota or trusted garage and get a full diagnostic on powertrain control module (PCM).
SPONSORED LINKS
Thursday, December 10th, 2009 AT 2:05 PM
Please
login
or
register
to post a reply.
Related Transfer Case Content
2005 Toyota Corolla
2005 Toyota Corolla 4 Cyl Front Wheel Drive 75000
Asked by
robertmconnor
2005
TOYOTA COROLLA
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
1996 Toyota Corolla 1996 Toyota Corolla Stops...
Transmission Problem 1996 Toyota Corolla 4 Cyl Two Wheel Drive Automatic Hi, I Have 1996 Toyota Corolla. It Suddenly Stops When I...
Asked by
samir_1976
1996
TOYOTA COROLLA
2007 Toyota Corolla Idle Prm Question
Engine Performance Problem 2007 Toyota Corolla 4 Cyl Front Wheel Drive Manual 52k Miles My 2007 Corolla S Always Idles At About 1100...
Asked by
corollaguy10
2007
TOYOTA COROLLA
1999 Toyota Corolla
Engine Performance Problem 1999 Toyota Corolla 4 Cyl Front Wheel Drive Manual 122k Miles Car Does Not (usually) Immediately Turn On...
Asked by
Himihon
1 ANSWER
1999
TOYOTA COROLLA
1989 Toyota Corolla 1989 Corolla Ignition System...
Engine Performance Problem 1989 Toyota Corolla 4 Cyl Front Wheel Drive Automatic How Does This Sytem Work To Advance The Spark? ...
Asked by
trini3232
1989
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
Axle Bearing and Rear Seal Replacement Rear 1/2 ton
Transmission Service - Manual
Online car repair manuals
