2004 Toyota Corolla Timing Belt Replacement
140,000 MILES • 4 CYL • FWD • AUTOMATIC
RIVERSM
I would like to know IF and HOW the engine could be damaged if the timiing belt fails on this vehicle.
Also - How frequently should the timing belt and water pump be replaced?
Thanks!
Mike Rivers
Jul 26, 2010 at 5:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The 2003-2008 Corolla doesn't have a timing belt; a timing chain is used instead. It should last the life of the vehicle. There is no set interval for replacing the timing chain or water pump.
Jul 26, 2010 at 10:00 AM
