2004 Toyota Corolla REPLACING A BATTERY
42,000 MILES • 4 CYL • FWD • AUTOMATIC
AYBA
My mechanic suggested a new battery. I went to Costco and read their manual.
Their manual stated to be careful about replacing some 2004 Toyota's batteries since it may require re-routing some wires.
Please advise
Thanks
Jul 18, 2009 at 2:44 AM
STEVEW84
  • 673 POSTS
The problem is would have with rerouting wires is if you had the wrong battery.
Jul 18, 2009 at 11:44 AM
MMPRINCE4000
  • 8,548 POSTS
Never heard that you had to re-route wires?
Disconnect negative cable first, then hold down, then positive, then battery.
4-5 years is usually the average life of a battery.
Jul 19, 2009 at 1:02 AM
STEVEW84
  • 673 POSTS
Why would you have to reroute wires for a new battery? The only reason I could see is if you had the wrong battery or if you were moving the battery.
Jul 19, 2009 at 4:40 AM
MMPRINCE4000
  • 8,548 POSTS
I agree with Steve on this, the other possibility is you have a stereo system wired directly to battery?
Jul 20, 2009 at 12:53 AM
