2004 Toyota Corolla Power door locks
106,700 MILES • 4 CYL • 2WD • AUTOMATIC
MAXSEPOWER
Hi, i just bought a 2004 corolla. and the issue is 2 of the 4 doors wont lock or unlock when i hit the lock/unlock switch. same thing happens if i hit the switch on the passenger door. now the doors that are not responding are the door behind the drive and the passenger door. just on more thing I can manually lock and unlock the doors meaning by hand. any ideas?
Sep 26, 2010 at 1:43 PM
MMPRINCE4000
  • 8,548 POSTS
Doors are locked by solenoids. Check fuse, relay, if OK then switch or solenoid.
You should be able to manually lock door with button or key.
Sep 27, 2010 at 1:51 AM
