I do not have any problem with the car at the moment.
Having said above, what would you recommend servicing on this vehicle? Transmission fluid change and oil change? Anything else? How much is the reasonable amount to spend on these services? Should I take it to toyota dealer or other local mechanic? I am in Houston, TX area.
Also, do I need to change timing belt on 2004 toyota corolla? If so when and how much would it cost?
Thank you so much in advance!
Wednesday, June 2nd, 2010 AT 7:53 PM
