2004 Toyota Corolla knocking noise in rear when brakes are
2004 TOYOTA COROLLA
EPIZZITOLA
Brakes problem
2004 Toyota Corolla Front Wheel Drive Automatic 145000 miles
had new drums and rotors shoes and pads now makes aconstant knock knock knock when appling brakes
May 20, 2009 at 9:17 AM
MMPRINCE4000
  • 8,548 POSTS
The brakes were installed improperly or the drums/rotors are out of round.
Take back to installer, have them check for loose hold downs, broken springs, and if necessary have them turn drums (on rear). Also have front checked for warped rotors, loose caliper bolts, pads installed improperly, caliper slide pins that do not move freely.
Toyota rear drums/front pads are relitively simple compared to other brands.
May 21, 2009 at 6:12 AM
