Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Trouble Codes
P Codes (Powertrain)
P0500 - P0599
P0505
2004 Toyota Corolla Idle control system
2004 TOYOTA COROLLA
56,000 MILES • 4 CYL • 2WD • AUTOMATIC
WEWELLSJR
MEMBER
1 POST
P0505 appeared when I had a diagnostic done on the car Idle Control System Malfunction what should I do?
Jun 12, 2009 at 4:00 PM
MMPRINCE4000
Experienced Mechanic
It is an idle speed error, the idle speed is not within the parameters specified by PCM.
It is generally the IAC (Idle Air Control) valve malfunction.
You can try removing and cleaning or replacing, or if you do not feel you can do this, take to a trusted garage.
Jun 13, 2009 at 1:08 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
