should I change the transmission fluid ?
38,000 MILES • 4 CYL • FWD • AUTOMATIC
FRAN42
I have a 2004 Toyota Corolla automatic with 38,000 miles and the car runs great. When should I change the transmission fluid or do I even need to have it changed? The the dip stick label states no need to change under normal driving conditions; which I drive.(the car shifts fine) Best Regards, Guy
May 19, 2009 at 7:59 AM
MMPRINCE4000
  • 8,548 POSTS
Yes the trans. fluid has no scheduled maint. change (if driven under normal driving conditions).
Just change oil every 3,000-5,000 miles, change/flush coolant every two years (use Toyota coolant ONLY), inspect belts, hoses every year, change air filter every year.
Look for any fluid leaking (puddles/drips) when you park car.
Only other maint. is to change plugs every 100K use Denso/NGK Iridium.
Check your owners manual maint. schedule for more info.
May 26, 2021 at 11:17 AM
FRAN42
Thanks for answer..,you guys are the "Best".
Best Regards,
Guy
