HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Symptoms
Backfire
SPONSORED LINKS
2004 Toyota Corolla engine misfire and spitting back
AKINDJ
MEMBER
2004 TOYOTA COROLLA
Engine Mechanical problem
2004 Toyota Corolla 4 cyl Front Wheel Drive Manual
I'll will like to know the cause of the faults and the possible solution or repair
Friday, November 5th, 2010 AT 8:45 AM
MMPRINCE4000
MECHANIC
Missing and backfiring would be a timing issue, generally the cam/crank sensor.
These should set the check engine light on?
Other possibilities are Mass Air Flow, or just bad plugs.
If plugs are original, start by changing them.
SPONSORED LINKS
Friday, November 5th, 2010 AT 9:12 AM
Please
login
or
register
to post a reply.
Related Engine Backfire Content
1990 Toyota Corolla Backfiring
Why Is It My Engine Backfiring? Please Advise!
Asked by
baroy
1 ANSWER
1990
TOYOTA COROLLA
VIDEO
How To Fix an Engine Backfire
Instructional repair video
GUIDE
Backfire Repair
When your engine backfires it can do so in one of two ways. First and the most common way is when the engine is running a small explosion of unburnt fuel is ignited inside...
1998 Toyota Corolla Engine Backfiring
Engine Mechanical Problem 1998 Toyota Corolla 4 Cyl Front Wheel Drive Manual 189000 Kms My Toyota Corolla Fitted With A 2e Engine 1300cc...
Asked by
namz
1 ANSWER
1998
TOYOTA COROLLA
Jerking Backfiring Toyota Corolla
Toyota Corolla 1989 400, 000 K's 1.6 L Sedan. When I Drive The Car For A Little While It Will Heat Up And Then The Problem Occurs When I...
Asked by
redragon
TOYOTA COROLLA
Have A 1995 Corolla 1.8 Lt Engine Idles Fine With A...
Change Plugs, Wires, Check Injectors, Fuel Pump, Distributor Cap. Did Not Change Timing Belt Could The Belt Cause This? Have A Question On...
Asked by
Livingston38
1995
TOYOTA COROLLA
1997 Toyota Corolla Engine Doing Coughts ( Speed...
At The Moment Of Reach The Speed Of 45 Miles The Car Start Coughing Until Get 55 Miles Still Is Doing The Same. But After 55 Miles The...
Asked by
ggvazq1
1 ANSWER
1997
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Misfire
Misfire Random Code P0300
Online car repair manuals
