2003 Toyota Corolla wrong key stuck in the ignition switch
2003 TOYOTA COROLLA
SHEWAG
2003 Toyota Corolla All Wheel Drive Manual
(2003) toyota corolla nze lx limited 121 my driver inserted a wrong key into the ignition but its not fully inserted it had gone a little now the key is stuck in the igniton the steering wheel also locked. how to get the key out now?
May 13, 2010 at 3:54 AM
MMPRINCE4000
  • 8,548 POSTS
You will have to remove the lock cylinder. Contact local locksmith, since the cylinder is probably damaged.
May 14, 2010 at 12:55 AM
