2003 Toyota Corolla would not work as list wiper siganl def
DUC10051959
Electrical problem
2003 Toyota Corolla 6 cyl Front Wheel Drive Automatic 125.00 miles
relay or fuse problem that make the list wiper signal shift lock radio fan blower .. would not work what to fix fuse or relay
Jul 22, 2010 at 4:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Test out fuse labeled DOME (15 amp) in the engine compartment junction block. Also test fuse labeled ECU-IG (10 amp) in the instrument panel junction block as well as fuse labeled GAUGE (10 amp) in same instrument panel block.
Jul 22, 2010 at 11:37 AM
