2003 Toyota Corolla When should I get a tune-up?
2003 TOYOTA COROLLA
55,000 MILES • 4 CYL • AWD • AUTOMATIC
AKUNG
Thank you very much for your reply to my earlier question. When should I get a tune-up and when should I change my anti-freeze?
Jun 18, 2008 at 4:34 PM
MMPRINCE4000
  • 8,548 POSTS
Check the owners manual for a maintenance schedule. Newer Toyotas are equipped with iridium plugs which last around 100k miles.
If you follow the maint. schedule in the owners manual, it is the best guide to use with regard to maint.
Also check the CV boots for rips and tears and look for any leakage (oil, transmission fluid and coolant) and have it fixed. Inspect the brake pads and rotors for wear and brake hoses for leaks/bulging.
I would also change oil/filter every 5,000 miles.
Jun 19, 2008 at 1:13 AM
