2003 Toyota Corolla wet carpets / leaks
2003 TOYOTA COROLLA
80,000 MILES • 4 CYL • 2WD • MANUAL
GEORGIE524
After some months, someone pointed out a mildewy smell in my car. Investigation demonstrated a wet carpet on the driver's side back seat area. I've been trying to dry it w/ heat and blow-drying, but every time you press on the carpet it gets wet again, so apparently there must be a small 'puddle' underneath. Question 1: will I need to pull up the carpet or cut it to gain access to the floor of the car to properly dry it? Question 2: Is there a commercially available fix that is reasonably priced. I've been told not to let it continue because breathing in mildew is not healthy. Also, does this condition indicate that there is likely a leak that keeps the water collecting there, and where should I look for that leak. (There is a a sunroof on the car, but in the past, if it is clogged, it drips onto the driver and front seat passenger). Thanks to anyone who can help me
Dec 14, 2009 at 10:18 AM
MMPRINCE4000
  • CAR REPAIR CONTRIBUTOR
  • 8,548 POSTS
Yes I would remove carpet and find source of leak. It may be a seam in body is leaking and would simply require some RTV sealant to fix.
But yes repair ASAP as mold can be dangerous.
Dec 15, 2009 at 7:13 AM
