My carolla drives very loud and vibrates at highway speeds. The noise and the vibrations seem to be toward the back around the rear axle. About a year ago I had the wheel bearing on the passenger side replaced and seem to cut the noise and vibration down only for a couple of days. Since then I just passed the noise and vibration off as having old tires and needing to replace them. However, a friend said that it probably won't help and that a CV joint might be busted? I thought CV joints were in on the front axle? My question is what might be causing the noise and vibrations and how can I fix it?
Jul 1, 2008 at 5:05 AM
