2003 Toyota Corolla Vibrations at highway speeds
2003 TOYOTA COROLLA
152,000 MILES • 4 CYL • FWD • AUTOMATIC
TBD4915
My carolla drives very loud and vibrates at highway speeds. The noise and the vibrations seem to be toward the back around the rear axle. About a year ago I had the wheel bearing on the passenger side replaced and seem to cut the noise and vibration down only for a couple of days. Since then I just passed the noise and vibration off as having old tires and needing to replace them. However, a friend said that it probably won't help and that a CV joint might be busted? I thought CV joints were in on the front axle? My question is what might be causing the noise and vibrations and how can I fix it?
Jul 1, 2008 at 5:05 AM
KHLOW2008
  • 41,814 POSTS
Hi tbd4915,
Took you one year to decide that you can't take it anymore? What if it had been a safety issue? That is not what drivers attitude should be.
Most probably the wheels are out of balance or the rims are bent.
There are no CV joints at the rear.
Jul 1, 2008 at 5:53 AM
