2003 Toyota Corolla Stuttering engine
NTABO
Engine Performance problem
2003 Toyota Corolla 4 cyl Front Wheel Drive
The engine stutters at starting(especially when it is cold) but this stops after about 30 seconds. If I move immediately after starting it does not respond to the accelerator stuttering for a few seconds before responding. The problem disappears when the engine warms up. I have changed the plugs and the fuel pump but the problem persists.
Thanks for your attention
ntabo
May 1, 2010 at 2:31 AM
BMRFIXIT
  • 19,053 POSTS
start by injector leak test
try this turn key on engine off
wait a min turn key off and then on do it 3 times
and then start
May 1, 2010 at 2:24 PM
