Reset Check Engine Light?
2003 TOYOTA COROLLA
NIR
Hello.
I had "check engine" light on with diagnostics code p0420, replaced the catalytic converter, but the Check engine light is still ON.
How do I reset it?
Thanks.
Aug 17, 2008 at 8:40 PM
  • 31,937 POSTS
Hi there,
THis video will show you how to clear the codes
https://youtu.be/ahK_eucFi-k
Mark (mhpautos)
Apr 28, 2020 at 4:21 AM
MTMOTORIST
I have 1999 TOYOTA COROLLA 2 month ago I got P 0466 fail code then I change Charcoal Canister Then reset ECM CHECK ENGINE light became off.But now i cannot pass smog check because too hi CO.. I already change spark plugs injectors-nothing changes.. Car runs good ,doesn,t eat gas, CHECK ENGINE off-no one can tell me exactly what else am i supposed to change?????
Aug 9, 2020 at 5:00 AM (Merged)
Could be one of the following the coolant temperature sensor,oxygen sensor, leaking injector/s and fuel pressure regulator,excessive fuel pressure and restricted air intake
