2003 Toyota Corolla IAC Valve
80,000 MILES • 4 CYL • FWD • AUTOMATIC
RGRANATH
How hard is it to replace the IAC Valve on a toyota corolla. Will the check engine light go on when it is replaced?
Oct 30, 2008 at 8:02 AM
MMPRINCE4000
  • 8,548 POSTS
It bolts to throttle body. You should always disconnect the negative battery cable to change any sensor.
The PCM will relearn the correct setting (or steps) after a few miles. You should not get a check engine light, unless you forget to reconnect the harness.
Oct 31, 2008 at 1:05 AM
