Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Interior
Cruise Control
2003 Toyota Corolla cruise control
2003 TOYOTA COROLLA
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
LENNYLOVE111
MEMBER
1 POST
the cruise control keeps coming off. it works for a while first ten miles. then it keeps popping off.mile on then a mile off
Feb 16, 2009 at 9:39 AM
MMPRINCE4000
Experienced Mechanic
Cruise will only work above a certain speed, around 40.
It is also dependant on coolant temp and other sensors and gear selection.
Make sure the brake switch is working, it will not work if brake switch is bad.
Could also be the cruise switch, vacuum leak.
Feb 16, 2009 at 11:18 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
