2002 Toyota Corolla Turn signals do not work
2002 TOYOTA COROLLA
VMOODLIAR
2002 Toyota Corolla 4 cyl Automatic
I had the emergency signals on one day for a duration of 10-15 minutes and after that the turn signals do not work. The dashboard indicators of the left and right turn do not blink. When I look from the outside the turn signal lights are not blinking either. This is the first time I've experienced such a problem. Any ideas on how to fix it?
Jun 17, 2008 at 4:21 PM
  • CAR REPAIR CONTRIBUTOR
Check the turn signal fuse 7.5amp, Hazard switch and flasher. The power starts at the fuse then to hazard switch thru the flasher then to the combination switch then to the lights.
Jun 17, 2008 at 4:47 PM
KHLOW2008
  • 41,814 POSTS
Hi vmoodliar,
If the lights are working without blinking, the relay needs replacement.
Jun 18, 2008 at 8:58 AM
