2002 Toyota Corolla Pprobable exhaust manifold leak
157,000 MILES • 4 CYL • FWD • MANUAL
R_ROD2002
When I accelearate in 2nd gear, i hear a noise which sounds like there is some sort of exhaust leak coming off the engine on the driver's side. I took it to Midas Muffler and they were unable to find a leak and suggested a possible exhaust manifold leak which they would be unable to diagnose. What should I be considering as a problem?
R. Rodriguez
Jun 28, 2009 at 6:24 PM
MMPRINCE4000
  • 8,548 POSTS
Remove the heat shield and look for burn marks on head. It is also possible that the manifold is cracked, or a bolt has worked loose.
Fix ASAP, exhaust leaks can cause a lot of damage to wiring and other components.
Jun 29, 2009 at 1:12 AM
