2002 Toyota Corolla Noise
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
RAMGAN
Noise in the suspension sys
Oct 1, 2009 at 2:51 AM
MMPRINCE4000
  • 8,548 POSTS
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Oct 1, 2009 at 3:11 AM
