2002 Toyota Corolla No low beams
RONE06
Electrical problem
2002 Toyota Corolla Front Wheel Drive Automatic 110000 miles
Both low beams (headlights) are not working but the High beams do. I have checked the fuses and they check good with a volt meter while installed. I could feel the relay energizing when I would pull it out and then reinstall it I could also hear the change of state in the relay. What would you suggest I check next? Is it possible the switch has gone bad in the low beam position? I am thinking it is something common between both right and left headlights Any help?
Thanks
Dec 9, 2009 at 3:21 PM
  • 75,988 POSTS
Check main fuse 40amp and head relay
Dec 9, 2009 at 3:50 PM
