2002 Toyota Corolla Low beams not working.
2002 TOYOTA COROLLA
DANTELLIER
The low beam headlights and daytime running lights went out on my corolla I have replaced the bulbs and fuses and they still do not work. All of the rest of the lights on the car are functioning including high beams. What could likely be causing such an issue.
Jan 29, 2009 at 2:43 PM
ZACKMAN
  • 4,202 POSTS
https://images.2carpros.com/forum/automotive_pictures/55316_02corollaheadlight_1.jpg
https://images.2carpros.com/forum/automotive_pictures/55316_02corollaheadlight2_1.jpg
Need you to check all these. Engine junction box- left side 1. Dome fuse 15A 2. Main fuse 40A 3. Headlamp fuses (L and R) 10A 4. DRL fuse 7.5A 5. L/Beam headlight fuses (L and R) 10A Engine room relay box - radiator support 6. DRL relay Behind dash, above glove box 7. Main DRL relay
Mar 31, 2021 at 12:55 PM
