2002 Toyota Corolla hard gas pedal and poor accleration
2002 TOYOTA COROLLA
167,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBSTOY
  • 14 POSTS
hey 2carpros;
My question how do i know if a throttle cable is bad; my gas pedal is hard to depress; sometimes have to keep foot to floor or criuse contol on to relax foot.
Is tps sensor related to this problem?
Also i notice a slight hesition when eng is cold. I replaced the electric fuel pump; fuel filter; and sock but still no change. Could the new pump be incorrect? The eng compress is good at 200 psi and fuel pressure with in range.
A chek eng light came on for infecient cat which Meineke replaced' I'd appreciate your imput. Rob
Jul 19, 2009 at 6:43 AM
MMPRINCE4000
  • 8,548 POSTS
The cable to throttle body may be binding, or the throttle plate is binding.
Rotate TB cam by hand and see if it operates smoothly, if so then cable is suspect.
Look at cable routing and cable for kinks.
Jul 20, 2009 at 1:30 AM
ROBSTOY
  • 14 POSTS
I chek all throttle cables; the cable from the throttle body to the transmissions binds and doesnt return; so maybe thats the problem and has a kink.
Thanks for your imput
Jul 24, 2009 at 5:52 AM
MMPRINCE4000
  • 8,548 POSTS
Thanks for the donation and using 2carpros.
Jul 25, 2009 at 12:29 AM
