2002 Toyota Corolla Engine stalling when cold
63,500 MILES • 4 CYL • 2WD • AUTOMATIC
LAARNI
After overhauling my engine, after 5 months, the old problem is back. It stalls when i start early in the morning after starting it on for about 4 minutes.
Toyota has done an intelligent testing using their machine and it says it is ok.
I spent a lot in my overhaul, pls. help
Oct 9, 2009 at 4:41 PM
MMPRINCE4000
  • 8,548 POSTS
If it stalls and starts right back up, then I would look at a possible IAC (idle air control valve).
Did it stall when Toyota looked at it?
Oct 10, 2009 at 1:23 AM
