2002 Toyota Corolla clicking/cranking noise
10,000 MILES • 4 CYL • FWD • MANUAL
KATHYTHEANGEL
cranking noise when I accelerate not when I am in neutral
Jun 5, 2009 at 3:30 AM
MMPRINCE4000
  • 8,548 POSTS
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Try the above first, if noise is worse in turns, it is most likely CV joints.
Jun 6, 2009 at 1:47 AM
