Tires and Wheels problem
2002 Toyota Corolla Automatic
I have been hearing a slight clicking coming from my front wheels while I'm driving, fast or slow. I don't know what it could be.
Friday, November 6th, 2009 AT 12:48 AM
MECHANIC
HI there, have the CV joints in the drive shafts inspected as this can cause a click, you will hear this often when driving around corners.
Mark (mhpautos)
SPONSORED LINKS
Friday, November 6th, 2009 AT 2:56 AM
MMPRINCE4000
MECHANIC
To add to Mark's great advice:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
