2002 Toyota Corolla Clicking noise
30,000 MILES • 4 CYL • 2WD • MANUAL
KCT1
Hi, I have a Toyota corolla 5 door vvT3 and am getting a clicking sound when driving that resembles the teeth of a hair comb being flicked slowly with the thumb nail, more noticeable when in fith gear. It is almost like an oversound against the engine noise (which is normal when reved from idle) and increases in speed when acceleration is applied. Is this normal, or is it to do with the gearbox?
Best regards
Keith
Feb 6, 2009 at 8:58 PM
MMPRINCE4000
  • 8,548 POSTS
Check CV joints for rips tears in boots first.
Check motor/trans mounts. Fluid level in trans.
If all checks out, it may be clutch as opposed to trans.
Feb 7, 2009 at 12:27 AM
KCT1
Thank you for your swift reply. I will check these out as you suggest.
Regards...Keith
Feb 7, 2009 at 12:31 AM
