2002 Toyota Corolla bearing
45,000 MILES • 4 CYL • 2WD • MANUAL
SARDINIA
The car makes a winding sound when I steer toward the right, especially at higher speeds. I noticed it a year ago when it started out, at first, faint and hardly noticeable. Recently it's more pronounced. What other part costs might I be looking at if the bearings have to be replaced? What is the normal repair price for something like this? Any common ploys I should watch out for when trying to get this worked on?
thks
Steve
Sep 8, 2009 at 9:32 AM
MMPRINCE4000
  • 8,548 POSTS
Toyota's have pressed in bearings, not hub assemblies. You must remove the entire front knuckle and have the bearing pressed out/in.
Before replacing the bearing, try this:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Sep 8, 2009 at 10:28 PM
