2002 Toyota Corolla Axle Bearings
115,000 MILES • 4 CYL • 2WD • AUTOMATIC
BLDSCOTT
I just took my car to a shop who charged me $40 to tell me my axle shakes a lot to the point they believe my axle bearings need to be replaced and suggested I take it to a transmission shop. They guy said it was very unusual for a car of my mileage to have this issue. He was also shocked that the seal was not leaking transmission fluid but thought if it wasn't fixed soon it might not only leak, but actually break and then I'd have a bigger problem. He also said my rt front tire bearing needed to be replaced which he could do but thought I should start with the axle bearings. What would axle bearing replacement cost? Separate from that what does a wheel bearing replacement cost?
Jun 11, 2010 at 10:59 AM
MMPRINCE4000
  • 8,548 POSTS
Toyota uses pressed in bearings, the knuckle has to be removed and bearings pressed out/in.
You are probably looking at $500-600.
Jun 12, 2010 at 1:13 AM
TEXASB22
  • 11 POSTS
for my front 2 they were about 62$ for each and then i had a guy press them in for 25 each.
Oct 13, 2010 at 9:47 AM
MMPRINCE4000
  • 8,548 POSTS
You got a deal! :)
Oct 14, 2010 at 1:57 AM
TEXASB22
  • 11 POSTS
if its the same thing you were talking about it was my wheel bearings but yeah did it myself first time working on a car was fun but now im doing the other side today so will see lol thanks for all yoru help feedback and donation coming....
Oct 14, 2010 at 5:15 AM
MMPRINCE4000
  • 8,548 POSTS
Thanks for using 2carpros.
Oct 14, 2010 at 11:58 PM
