2001 Toyota Corolla Toyota Corolla rear camber Bolt
ROCKJEONG
  • 2001 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 84,200 MILES
Hi
Precision tune mechanic says my car needs new rear camber bolts installed for allingnment. I tried to find rear camber bolt on the internet, but could not find except front ones. I went to NAPA auto part but, they did not have.
Does 2001 Corolla have rear camber bolts? Are they needed for allignment?
Thank you for your help.
From Minnesota.
Saturday, February 7th, 2009 AT 11:02 AM
MMPRINCE4000
  • 8,548 POSTS
Doesn't NEED them. but they do make camber adjustment easier. They are bolts with side cut flat so they fit inside an eccentric "cam" washer, that allows camber movement by turning bolt against washer cam.
Ask Toyota if they are needed, or available, if not take to an alignment shop that can align it without, or uses shims to adjust camber.
https://www.2carpros.com/forum/automotive_pictures/108325_camber_1.jpg
https://www.2carpros.com/forum/automotive_pictures/108325_camber_2_1.jpg
Sunday, February 8th, 2009 AT 8:31 AM
