2001 Toyota Corolla OXYGEN SENSOR
JACQELINE_STL
Engine Mechanical problem
2001 Toyota Corolla 4 cyl Automatic 18000 miles
WHERE ARE THE OXYGEN SENSOR LOCATED AND HOW MUCH WILL IT COST TO REPAIR?
Nov 29, 2008 at 7:32 AM
MMPRINCE4000
  • 8,548 POSTS
There are at least two, one upstream and one downstream.
They are in the exhaust system. Bungs, welded to the exhaust pipes hold them in place, they screw in to the threaded bung.
The upstream is before the convertor, and the downstream is located after the convertor.
You can rent O2 sensor sockets to remove them from most autoparts stores.
Price is generally anywhere from $50-100 each.
Use antisieze compound on the O2 threads when you install new ones.
Nov 29, 2008 at 11:34 PM
