2001 Toyota Corolla oil light
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
ARGELIO01
i have a 01 corolla, when i start the vehicle, the oil light stay on for about 5 seconds then dissapear. after the oil change, the light stay on all the time and i hear some noise but i just turn it in off, why that thing happen. i appreciate your help with this matter thanks
Dec 4, 2008 at 1:58 PM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge if normal -replace the oil pressure switch-abnormal could mean the oil pump and engine bearings -Lil bit concern about the noise you hearing-could mean the engine bearings-
Dec 4, 2008 at 2:04 PM
