2001 Toyota Corolla Lose of oil pessure
2001 TOYOTA COROLLA
CHEVYFEVER
  • 7 POSTS
Engine Mechanical problem
2001 Toyota Corolla 4 cyl Front Wheel Drive Automatic
In another shop they cleaned the oil pump strainer cause the oil light started to turn one while driving so they cleaned the oil pump strainer and told him the it would be good to change the bearings of the crankshaft and piston rods.So I pulled the engine out and change the bearing plus the oil pump.To be on the safe side I put a gauge to see the pressure.It was about 40psi at idle and 60psi at 1500rpm and then it started going down and down until it got to 0 and the oil light turned on. I shut it off and after a while turned it back on and pressure ok and after about 5 to 8 minutes it went down to 0.The pressure went down slowly.I was thinking of taking the head off a taking it to a machine shop so they can check the head and camshafts.Can the Camshaft Oil Control Valve have to do something with the lost of pressure? Need help Thanks
Nov 25, 2009 at 7:29 AM
MMPRINCE4000
  • 8,548 POSTS
It sounds more like the main bearings. Are you getting a knock noise?
Nov 26, 2009 at 12:47 AM
CHEVYFEVER
  • 7 POSTS
I changed the main bearings and the rod bearings and installed a new oil pump,and there is no knock noise.
Nov 26, 2009 at 3:41 AM
MMPRINCE4000
  • 8,548 POSTS
Are you measuring oil pressure with a mechanical gauge?
The camshaft control valve is part of the VVTi system.
If indeed (with mechanical gauge) your OP is going to zero, it is a bearing clearence, clogged galley problem.
Nov 26, 2009 at 9:57 PM
CHEVYFEVER
  • 7 POSTS
Bearing clearence is in specs.The gauge is mechanical.I am thinking it can be a clog in the system and the oill does not return to the oil pan as fast as it should be and the pump starves.Am I in the right track?
Nov 27, 2009 at 2:05 AM
MMPRINCE4000
  • 8,548 POSTS
Sludge build up could be the problem, does engine have a lot of sludge?
Could also be an oil galley is blocked, in any case, you will have to get good oil pressure or you will be back in the same boat in a short time.
Nov 28, 2009 at 12:07 AM
CHEVYFEVER
  • 7 POSTS
What I'm giong to do is take the engine out again and lift the cylinder head and check all the drains and oil galleys.
Nov 28, 2009 at 5:55 AM
MMPRINCE4000
  • 8,548 POSTS
I would first take the oil pan off and check the pickup.
Nov 29, 2009 at 1:42 AM
CHEVYFEVER
  • 7 POSTS
As I said at the top the pickup was cleaned,bearings changed and a new oil pump.
Nov 29, 2009 at 7:37 AM
MMPRINCE4000
  • 8,548 POSTS
Yes I know, I was just wondering if it hase come loose or may have a leak in it, clogged screen?
Nov 29, 2009 at 10:47 PM
CHEVYFEVER
  • 7 POSTS
I'll check and see.
Nov 29, 2009 at 11:16 PM
CHEVYFEVER
  • 7 POSTS
Well I'm back,took the engine out again and sent
the cylinder head to a machine shop to check if
it was warped at the camshafts,but no.I checked
all the passages and none were blocked,but still
the pressure goes to zero after it runs after five
to eight minutes.Any ideas would be accepted.
Jan 3, 2010 at 12:06 AM
