2001 Toyota Corolla Headlight
146,000 MILES • 4 CYL • 2WD • AUTOMATIC
MBOURNE
I had a fuse blow out on me the other day when I was driving, my stereo went out, well I got the fuse replaced no problems with my stereo now. But now my passenger side headlight is out. I checked that fuse and its fine, checked the bulb and its fine also. Im wondering if it could be the wire connection to the light. I notice before I had a problem with the same light when I had a battery problem, I closed the hood and the light went out, then back on later on, like I have a loose connection. Do you think it could be my wiring? And where could I buy that wire connection if that is the problem?
Jan 29, 2009 at 1:21 PM
MMPRINCE4000
  • 8,548 POSTS
Sure sounds like an open connection. First inspect the wiring to the headlight connector, if OK, then you will probably have to get the connector from Toyota and splice it in.
Jan 29, 2009 at 1:45 PM
