2001 Toyota Corolla Fuel system
73,000 MILES • 4 CYL • 2WD • AUTOMATIC
BHOOD91
Every time I go to fill up my gas tank my car has trouble starting after I put gas in it. This only happens when I go to fill up with gas. I put the new gas in then I turn the key and the car studders for a couple of seconds and then will finally catch and start up. I dont know if pressure is missing somewhere or what but I need to get this fixed.
Mar 27, 2010 at 5:43 PM
MMPRINCE4000
  • 8,548 POSTS
If you do not have a check engine light, then have the EVAP system checked at a dealer or trusted garage, there may be a blockage, leak or bad purge solenoid.
Mar 28, 2010 at 1:18 AM
