2001 Toyota Corolla front end screeching
CATOWIL
  • 2001 TOYOTA COROLLA
  • 4 CYL
  • 66,670 MILES
I took my car to have the brakes checked because when I stop at times (not always), there is screeching coming from under the front of the car. The brakes were checked twice and I was told they were okay. They drove the car but said they did not get the screeching sound. I know I'll probably have to take the car to the dealer but I wanted some idea up front of probable causes of the screech.
Note: It's not scrubbing but sqealing. Please help!
Tuesday, December 29th, 2009 AT 6:34 PM
MMPRINCE4000
  • 8,548 POSTS
If you are able, remove wheels and spray the rotors and pads with brake clean, you may have some debris between the pad and rotor (like a small rock) that is causing the noise.
Pads could be glazed, rotors could have grooves worn into them.
Toyota will probably want to change rotors and pads, and it will cost several hundred dollars.
Wednesday, December 30th, 2009 AT 6:56 AM
BLUE1128
I'm not a mechanic myself but I agree with him that it might be caused by debris. Check if there's something stuck in between the wheels. It's good to have your car checked atleast once a month.
Friday, January 1st, 2010 AT 4:36 AM
