2001 Toyota Corolla failed smog check
19,970 MILES • 4 CYL • 2WD • AUTOMATIC
BUTA
hi,
my toyota recently failed smog test with only 1 problem.
NO (PPM) ------ MAX 477,AVE 16, MEAS 764. so on
15 mph tested too much. can you point out what can cause this? thank you kindly.
Apr 20, 2010 at 3:09 PM
MMPRINCE4000
  • 8,548 POSTS
NOX emissions are high when the EGR valve is malfunctioning. Remove, clean, see if that helps.
Apr 21, 2010 at 1:56 AM
