2001 Toyota Corolla Engine/Transmission
2001 TOYOTA COROLLA
87,000 MILES • 4 CYL • FWD • AUTOMATIC
KEVDOG1842
I pulled the engine out of the car already and now I need to disconnect the transmission from the engine to put it on a stand. What steps do I need to take to remove the transmission from the engine without messing anything up? Thank you.
-Kevin
Nov 17, 2009 at 8:56 AM
MMPRINCE4000
  • 8,548 POSTS
Firts open the access panel and disconnect the flexplate to convertor bolts.
Loosen oil pan, support trans, remove trans bolts, pull trans straight out.
Nov 17, 2009 at 9:53 PM
