2001 Toyota Corolla engine problems
32,000 MILES • 4 CYL • 2WD • AUTOMATIC
STAAR15
When i am driving my car i often get random spikes on the horsepower (RPM) meter as if i am pressing down the gas pedal, but i am not. it seems the car is reving itself at times. what are some possible problems.
Dec 11, 2009 at 8:01 AM
MMPRINCE4000
  • 8,548 POSTS
If the engine is not reving, just the gauge moving, then most likely gauge or intermittent open circuit.
You will need to take to trusted garage or dealer for further diagnosis.
They can monitor PCM RPM output to see if signal is bad or gauge is problem.
If engine is reving, then you may have a transmission slipping. Get that fixed ASAP, as it will only get worse.
Dec 11, 2009 at 11:56 PM
