2001 Toyota Corolla ENGINE PROBLEM
137,000 MILES • 4 CYL • FWD • AUTOMATIC
CHONGVUE
my 2001 toyota corolla is making a clicking like noise. I don't know much but it is making my car accelerate much more slower and doesn't pick up as fast as it used to. I repair the spark plugs and still the same. Im going to try injector fuel to see if any changes. Could it be the sensor? Any suggestions?
Aug 20, 2010 at 6:50 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 20, 2010 at 12:50 PM
