2001 Toyota Corolla Engine pinging
80,000 MILES • 4 CYL • FWD • MANUAL
E30WWU
First off, thanks for the help.
My car is detonating badly between 3k rpm and and 3.5k rpm. I have replaced the MAF sensor, spark plugs, air filter, and Oxygen sensor. There is no engine check light of any kind. I have taken it to a Toyota dealership and they were stumped.... the told me to run a bottle of engine cleaner through the gas tank. That didn't fix anything. I also ran a can of seafoam through the intake manifold to help with carbon build up. That didn't work either. What should I do next? Thanks for the help.
Sincerely,
Bryan
Aug 30, 2008 at 4:09 PM
MMPRINCE4000
  • 8,548 POSTS
Possibly a bad crankshaft sensor, or related to the VVTi (Varable Valve Timing).
Have Toyota check the timing and VVTi activation with a scan tool, another possibility is the PCM is bad.
Aug 31, 2008 at 12:21 AM
