2001 Toyota Corolla Engine Knock when accelerate
138,000 MILES • 4 CYL • 2WD • AUTOMATIC
PIOJO
The noise I’m experiencing is when the engine goes above 2.000 RPM and the throttle position is almost at 50% or more, when the gas is depressed the noise goes away, for example this type of noise is exactly the same when you use a low octane gas on an engine that requires premium.
I have replaced the two O2 sensors and the check engine light still on, I went to AutoZone to get another diagnose and gives a huge list of all the sensors to check. At this point I don’t what to do I’m not sure if this is a timing issue. I appreciate your help. Thanks
Apr 1, 2010 at 12:23 PM
MMPRINCE4000
  • 8,548 POSTS
It is most likely a timing issue (crank/cam sensor), or VVTI.
You would have to read timing in live data mode to confirm.
Apr 2, 2010 at 1:51 AM
