2001 Toyota Corolla Engine eating up engine oil in between
2001 TOYOTA COROLLA
HOYA2002
Engine Mechanical problem
2001 Toyota Corolla Two Wheel Drive Automatic 120000 miles
The engine has been consuming the engine oil at 2,000 miles during the period in between the last 2 oil changes. No external leak was detected. Prior to that, last oil change was at 4,000 miles. Engine flush was performed then and driving belt replaced.
Mechanic told me it would cost less than $1,000 to open and tear down the engine. Estimates for replacing valves and piston rings range under $2500.
Sep 20, 2010 at 6:55 AM
MMPRINCE4000
  • 8,548 POSTS
Toyota guidelines are 1 qt. every 1000 miles is excessive.
Sep 20, 2010 at 2:42 PM
