2001 Toyota Corolla CLUNKING SOUND WHEN DRIVING
170,000 MILES • 4 CYL • FWD • AUTOMATIC
TURBOTOP
Hi and thank you for your help.
I'm very frustrated. The car makes a severe clunking sound when driving. If you accelerate, and then leave the accelerator, the car goes KLUNK loudly. The tranny is ok - no slippage. The engine runs fine. 2 engine mounts have been replaced already but this hasn't fixed the problem. It seems that the rear engine mount could be bad, according to one mechanic. Another mechanic says, that the tie rods are bad since the passenger side wheel has play and makes a loud knocking sound when jostled on the bay. The tie rod argument makes sense, but could it be that the rear engine mount is also bad??
I am not keen to put much money into the car and am wondering what to do. Please advise at the earliest.
Nov 7, 2010 at 2:41 PM
MMPRINCE4000
  • 8,548 POSTS
Check mount by wedging a LARGE screwdrive between mount and frame, should be very little movement.
I would change tie rod ASAP, as a tie rod failure would cause loss of steering control.
Nov 10, 2010 at 11:26 PM
