Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Corolla
Engine
Camshaft
Seal
2001 Toyota Corolla CAM SEAL
2001 TOYOTA COROLLA
45,009 MILES • 4 CYL • FWD • AUTOMATIC
BWAYNE
MEMBER
1 POST
MY CAM SHAFT OIL SEAL KEEP COMING OUT WHAT COULD BE MY PROBLEM
Mar 15, 2009 at 10:41 AM
MMPRINCE4000
Experienced Mechanic
Either the oil seal is the wrong size or not properly installed.
I would use a Toyota part and correct seal driver.
It is also improtant the seal surface is clean.
Alsp possible the camshaft seal surface is knicked.
Mar 16, 2009 at 12:01 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
