2001 Toyota Corolla Auto to manual conversion
93,416 MILES • 4 CYL • 2WD • AUTOMATIC
PBARYSAS
I'm thinking about converting the transmission from auto to manual. I have the tools i just need the parts. What would i need and how much would it cost?
Aug 22, 2009 at 11:12 AM
MMPRINCE4000
  • 8,548 POSTS
You would need trans, shifter,cables, clutch pedal and bracket, clutch MC and slave, motor mounts, clutch set, possibly different CV axles, clutch safety switch, PCM, and possibly a different wiring harness.
Parts would be dependant on new or used.
Probably the best approach is to buy a wrecked (rear ended) Corolla and use it as donor.
This would be a BIG job.
Aug 23, 2009 at 1:32 AM
