2001 Toyota Corolla appox cost for repair
2001 TOYOTA COROLLA
13,300 MILES • 4 CYL • FWD • AUTOMATIC
STROBEL05
Hello, my daughter ran into a curb with the front right tire. Now the tire is bent very bad and I had to have it towed. ( the bottum of the tire is bent under and the top of the tire is bent outwards. About how much do you think this will cost?
Dec 30, 2008 at 10:55 AM
MMPRINCE4000
  • 8,548 POSTS
It is very hard to estimate the cost without inspecting the damage.
Most likely the control arm, axle, tie rods, ball joints would need to be replaced, but it could also have damaged the brake calipers, rotors, steering rack and possibility the transmission case.
Get an estimate (more than one if possible) and see what they say needs to be replaced.
Dec 31, 2008 at 1:36 AM
